Problem code P0410
Problem code P0410
I keep getting this code and I've done some research on it. I realize it has to do with the secondary air pump. So, far the relay, fuse and Pump seem to be working as they should. I've not got to check the diverter or solenoid as of yet. However, I beginning to wonder if it might be something else? Maybe an O2 sensor? The reason I say that is because when you clear the code I can start and move the car a dozen times and it will not throw the code. However, if I go on a long drive and then shut it off and restart it will reappear. The car doesn't seem to be sluggish or have any ill effects when the light is on. So, I'm at a loss on what's really wrong and what needs replacing? Any advice or help you can provide will be greatly appreciated
