Check Gauges light on, all gauges reading fine wtf
Old 12-30-2012, 04:29 PM
LS1Pariah's Avatar
Default Check Gauges light on, all gauges reading fine wtf
2001 Fbody drivetrain including gauge cluster in a 93 rx7. This setup has worked flawlessly for over 4 years. Been having alternator issues for a few months, replaced several, and also wired direct with a resistor to eliminate PCM control. It is currently wired for both, the PCM controls it, and if that circuit fails, I have a backup circuit with the resistor in place. After wiring it this way, the check gauges stays illuminated. I thought maybe it was due to both being in place, so I tried pulling the fuse in the circuit with the resistor and the light stays on. So then I went ahead and pulled the connector with the exciter wire off the alternator completely and the light goes away. Not really making any sense to me. I tried searching "check gauges" and nothing in the results looked like it would help. Anyone have any ideas?
Old 12-30-2012, 05:53 PM
Undertow74's Avatar
sounds stupid, but are you on less than a quarter tank of gas? on these cars there is no low fuel light, instead the check gauge light will come on
Old 12-30-2012, 06:40 PM
LS1Pariah's Avatar
Yeah when it first came on, I was at a 1/4 tank, and although it usually doesn't come on until I'm a little less than an 1/8 I went ahead and filled up and it didn't change anything. Again remember, when I unplug the exciter wire to the alternator the light goes out.
Old 12-31-2012, 08:05 AM
Save the manuals!
wssix99's Avatar
What voltage is showing up on your gauges? Are all of them in the normal ranges?
Old 01-03-2013, 10:35 AM
LS1Pariah's Avatar
Voltage is well over 13 when cold, calms down to just under 13 after warm. The gauge reads a little low according to a volt meter. All other gauges are reading in normal ranges. Temp around 205, fuel is currently full, and oil pressure between 60-80.
Old 01-03-2013, 03:51 PM
Save the manuals!
wssix99's Avatar
Did you change the exciter wire plug at all? If the wire is on the wrong terminal on the alternator, weird things could happen...
I was just reading the tech specs on the stock alternator and those unused pins on the exciter wire plug are actually live on the alternator. (The car's PCM just doesn't take advantage of them.)
Old 01-04-2013, 02:28 PM
LS1Pariah's Avatar
Yes we did change the plug as a precaution. I haven't verified myself that it is at the correct pin, just going on my father-in-laws word that he did it correctly. I will try to verify this.
Old 01-05-2013, 11:52 AM
bristol16's Avatar
Do the ECM/BCM use the same signal wire as the gauge? Hook a scan tool up and check voltage through the computer and verify it is the same as what the gauge is displaying.
Old 01-05-2013, 10:14 PM
chrysler kid's Avatar
I would double check your ground connections from the battery, and then try a verified GM new alternator. Nearly all of the remanufactured ones have problems. Could be an internal problem in your alternator
Old 01-10-2013, 02:44 PM
LS1Pariah's Avatar
The pin for the exciter is the same as it was before so that shouldn't be the problem. The PCM voltage is reading in sync with the gauge, and you can't buy new anymore, they are all remanufactured.
Old 01-10-2013, 05:32 PM
Save the manuals!
wssix99's Avatar
Do you have any other details on this? I'm not sure what all this means and what components are hooked up to what. Also not sure what "circuit fails" means.
Old 01-12-2013, 07:29 PM
LS1Pariah's Avatar
Basically if the PCM decides to not excite the wire to the alternator, which I was told by my dad (mechanic) has been a problem with my particular car, he has a separate 12v source with the 470ohm resistor in it going into the same wire. It's fused though, and I have pulled the fuse to eliminate it and the check gauges light remains on.
Old 01-12-2013, 08:42 PM
Save the manuals!
wssix99's Avatar
Never heard of that being a problem with F-Bodies... No ideas coming to mind...
Just curious - have you scanned the PCM for codes? Sure its "check gauges" and not "check engine?"
Old 01-13-2013, 06:06 PM
LS1Pariah's Avatar
Yep positive. Check engine is actually service engine soon and it's amber, this is check Gages which is spelled wrong but that's how it is in the cluster and it lights up in red.
Old 01-14-2013, 08:49 AM
Save the manuals!
wssix99's Avatar
I've never heard of an issue where the check gauges was on but one of the gauges was not reading an abnormal condition. Can you post a pic of your cluster with the car all warmed up?
Old 01-17-2013, 06:31 AM
LS1Pariah's Avatar
Yep, I'll get one on here when I get back in front of the car.
Old 01-17-2013, 06:50 AM
TransAmBlue's Avatar
Did you try removing all of the circuit you installed and resetting the pcm?
Old 01-20-2013, 02:14 PM
LS1Pariah's Avatar
TransAmBlue- No I haven't, how exactly do you reset the pcm?
Old 01-20-2013, 02:29 PM
Save the manuals!
wssix99's Avatar
Wow. I'm starting to wonder if there is an issue with the cluster, itself.
Old 01-20-2013, 05:26 PM
LS1Pariah's Avatar
Just remember, all I have to do is unplug the pigtail from the alternator and the light goes out. But then the alternator doesn't charge. I'm about to the point where I will just get a damn self exciting regulator installed into the alternator so I don't have any wires going to it. It's just weird that its been wired this way for awhile and the issue is new.
Quick Reply: Check Gauges light on, all gauges reading fine wtf
