routine oil change turned into guessing game
Old 01-14-2013, 09:08 PM
dsmfevr1's Avatar
Default routine oil change turned into guessing game
Ok guys I changed oil yesterday and found 2 chunks of metal that are Identical. I've searches and it seemed to be a needle bearing from rockers. Wrong. After all the pics on the web I began to beleive mine were bigger and a little more beat up. So I pulled a rocker and knocked the bearings out. In fact this one is larger.does anyone have any ideals.I just bought this car changed the oil. No noises.runs great. And is stock.
Old 01-14-2013, 09:57 PM
dsmfevr1's Avatar
http://www.facebook.com/photo.php?fb...levant_count=1
Old 01-14-2013, 10:00 PM
dsmfevr1's Avatar
finally got a pic up the object that was found on the magnetic oil plug is the larger one. the rest are needle bearings for reference.
Old 01-15-2013, 06:24 AM
dsmfevr1's Avatar
Any help is appreciated
Old 01-15-2013, 03:56 PM
dsmfevr1's Avatar
cmon guys someone has experienced this or knows what it may be. or should i not worry and just drive it.
Old 01-16-2013, 05:39 PM
JD_AMG's Avatar
cam dowel pin maybe?
You might want to try the internal engine section, you will get more attention there.
Either way I think I would want to take that engine apart just to be safe.
Old 01-16-2013, 10:05 PM
dhctss's Avatar
man that sucks hope it tuns ok. I just installed a magnetic plug I hope I never find anyting. Gl
Quick Reply: routine oil change turned into guessing game
