another coolant question
So the low coolant light comes about 5 minutes after the car has been running. I'll check the level on the dipstick in the reservoir before I start it and it is completely covered and dripping so I can't get a read on if the damn thing is low or not. Any ideas as to why the dipstick would be soaked all the way to the top?
My car does the same thing every now and again but when check my coolant its full and radiator full. I was told its the low coolant sensor that needs replacing. I hope this helps.
Ok just making sure. When you fill the radiator should you have the front end up, like on ramps, to prevent air bubbles? Something my buddy told me just want to know if that's necessary.
