Foamy Oil!?
Old 02-06-2013, 11:22 AM
777Shock777's Avatar
Default Foamy Oil!?
Heyyyy everyone!
Like the title says, I've been noticing my oil is slightly foamy.
I first noticed it last oil change when the oil was coming out, thought no big deal must be bad oil.
Well, I went to check my oil level today and when I pulled out the dipstick with the car fully warm it had some foamy oil on it, it has tons of little bubbles in it.
Old 02-06-2013, 12:20 PM
O2Form's Avatar
Air in the oil from a leaking oring at the oil pump....maybe
Old 02-06-2013, 05:57 PM
Hmm, could it be something to do with Condensation maybe?
Old 02-06-2013, 07:42 PM
Bacon's Avatar
How was the oil level? What color was the oil? Any milkiness to it?
Old 02-06-2013, 07:44 PM
It seemed to be the regular dark goldish color... And the oil level seemed to be in the operating levels, but I'm going to change the oil this weekend and take some pics.
:o hopefully nothing too serious.
Old 02-06-2013, 10:42 PM
LS6427's Avatar
Condensation......
Especially when you drive a short period of time. Oil doesn't get hot enough to burn off the water that accumulates in the crankcase.
Get it to operating temp for at least 15 minutes and see if it still remains....
Old 02-07-2013, 11:34 AM
Originally Posted by LS6427
Condensation......
I do drive short periods of time, and since its been about 20-30 degrees here..
M-F I drive about 15 minutes each way, so maybe thats what it is... Maybe this Friday I'll go drive around on the highway for 30 minutes or so.
Thanks for the input
Old 02-07-2013, 10:00 PM
joecar's Avatar
Post a closeup macro pic of the oil on your dispstick.
Old 02-08-2013, 02:27 AM
K i'll do that tomorrow morning!
Old 02-14-2013, 01:20 AM
K, finally got an image of the changed oil! (It was about due anyways).
This was when the motor was completely cooled down.
But as you can see BAM! FOAM!!! What do you guys think of this!?
Old 02-14-2013, 12:37 PM
joecar's Avatar
Is that from draining the oil shortly after running the engine...?
Looks like the pump is pulling air, as said above.
Old 02-14-2013, 01:01 PM
Nope this is after letting the car sit for about 7 hours.
So the Oil Pump would be pulling air?
Old 02-14-2013, 02:06 PM
Bacon's Avatar
That just looks like the bubbles you get from oil draining into the pan. How has your oil pressure been? If you are sucking air in I would expect the pressure to be lower since the air is more compressible than the oil. Have you tried driving longer periods to see if it clears up?
Take a picture of the dipstick after its been running
Old 02-14-2013, 02:54 PM
The bubbles looked like that basically just on the dipstick.
I've noticed my oil pressure gauge has been reporting 40+ for most of the time barely dipping into high 30s at a stop light (automatic).
But, I do have new oil and will take a picture of it today or tomorrow after running it to operating temps.
Old 02-14-2013, 03:01 PM
TransAmBlue's Avatar
Do you have any lifter noise? Tapping and clicking with the engine hot.
I never seen oil look like that and i've changed oil a few thousand times.
Have you used any oil additives?
Old 02-14-2013, 03:34 PM
joecar's Avatar
If it sat that long, then it's something else... probably how the oil drains out into your pail.
Old 02-14-2013, 04:35 PM
No oil additives or anything used... Its still a pretty stock LS1 that has never been disassembled or anything.
Yeah, it was definitely cold oil and a cold engine... I'll be sure to look again and snap a pic of the dipstick.
Quick Reply: Foamy Oil!?
