Blinkers dont work, need to replace flasher
take off lower dash panel and you should find it attatched to the right side of steering column. if its not there it probably fell off the clip and is probably over by the dash panel where the HVAC controls are. it just pops off the end of the wires and you can then just pop on the new one. it will look like a silver cylinder at the end of 2 wires. you should also check your blinker fluid level while you're at it. (jk on the last part lol)
