water pump ?
Save the manuals!
BTW - You got to be careful with this... obviously, getting the rod caught up in the belt while its next to your head would be a bad thing.
For your original question - any bearing can go bad and squeak. I'd expect a failing water pump to be leaking or weeping fluid, though.
Have you tried some belt dressing to see if the sound goes away. I was chasing a sqeak and it was dirt that tranferred from the belt to the pulleys into the grooves. Even different belts would make the noise but after I realized it went away with the dressing I cleaned all the grooves on every pulley and added another new belt and no more noise
