i need to get to the fuel tank how can i drain it
Old 03-04-2013, 04:59 AM
Posidon's Avatar
Default i need to get to the fuel tank how can i drain it
i need to take out the fuel tank so i can change the evap sensor on the fuel pump how do i go about draining the fuel tank is there some way of turning the fuel pump on to pump out the fuel if it makes any difference the car is a 2001 v6
Old 03-04-2013, 07:06 AM
BlackBetty99SS's Avatar
You can purchase a hand held pump from oreilly(or any other parts store). Put one end of the hose in tank and other into fuel jug . The fuel jug must b lower than the tank in order to work properly
Old 03-04-2013, 06:18 PM
JaYZeig's Avatar
i would disconnect the line at the fuel rail, run a hose somehow from that to a gas container, go to the fusebox, and jumper the fuel pump fuse to straight battery power, and let er drain..have done this many times.
Quick Reply: i need to get to the fuel tank how can i drain it
