(video) Jittery oil pressure needle?
Nope, it's still happening. Started doing it about a week or so after my cam swap. Not sure what exactly caused it but as long as my pressure is staying at a normal level I am not going to worry too much about it. I mostly see it at idle, when at highway speeds it stays decently steady.
LS1Tech Administrator
Received 1,486 Likes
I've seen my '02 do that on several occasions, from what I remember it only happens when it's hot out and I'm idling in gear at a stop light after driving for a while. Seems like it's done that for all the years and 10s of thousands of miles I've owned it. Stock/original sending unit and pump. I don't worry about it.
Save the manuals!
Looks normal to me. If the fluctuations get wilder, then its probably just your OPSU going out. If you get there and need to replace it, you'll want to do so with an official GM part.
I had to replace mine recently, made a mistake with an off-brand part, and came back to the GM unit. My car now looks like the video you posted. (Just small fluctuations.)
