02 camaro front end questions
Old 03-11-2013, 10:10 AM
sbrad148's Avatar
Default 02 camaro front end questions
I recently bought a 2002 Z28 the problem I'm having is when i slow down to a stop the front end is loud. Its hard to describe the noise, if i had to id describe it as a smooth rub. I don't get any vibration in the steering wheel and brakes are fine. I'm just wondering what are some possible causes for the loud noise. Any input is appreciated.
Old 03-11-2013, 05:44 PM
2000PewterT/A's Avatar
Brakes would be the first thing I would check and would be the most common source of noise coming to a stop.
Old 03-11-2013, 08:19 PM
garygnu's Avatar
check you rotors and pads.make sure you don't have a sticky caliper.how many miles on the car ?mite need new bearings.
Old 03-12-2013, 04:12 PM
BigMac76's Avatar
First thing do as was previously listed, check the condition of the pads and rotors. Look for any abnormal wear on either set of pads as this will indicate a possibly sticking caliper. If a caliper is sticking, the inboard pad (nearest piston) will be worn down in a manner that would look like it's got an angle on it. Do you notice if the car holds itself on a slight incline/downgrade when stopped? That can also be an indicator of a sticking caliper.
Or there could be some rubbing on the caliper. Basically just take off the wheels, check the rims and calipers for any wear marks while checking the pads and rotors.
Old 03-13-2013, 10:26 PM
sbrad148's Avatar
Default thanks
the car has 47,500 miles. Thanks for the reply's ill go ahead and check the brakes and rotors. Ill post the update to what i find.
Old 03-15-2013, 03:30 PM
sbrad148's Avatar
What about the front end bearings, how difficult are they to change?
Old 03-15-2013, 06:14 PM
BigMac76's Avatar
Pretty easy, but you will be replacing the hub, not just the bearings. Remove the caliper, pads, bracket, abs connector and the 4 bolts holding the hub.
Moog will run about $120ish, and Raybestos about $85 each.
Old 03-19-2013, 04:32 PM
sbrad148's Avatar
im going to replace the rotors and pads this weekend to see if its the problem before i order the hub assembly. Ill post some pics after im done. Again thanks for the advice.
Old 03-24-2013, 10:48 AM
sbrad148's Avatar
I replaced the rotors and brakes, still have the rubbing sound so I'm gonna order the hub assembly and try that out
Old 03-25-2013, 11:25 AM
1 FMF's Avatar
what kind of brake rotors and pads you using?
I had bought a set of cross-drilled & slotted rotors off ebay a while back and a decent set of pads. For the first 5k-10k miles they were ok maybe a little noisy but last year they got really really bad and would groan like crazy whenever braking normal. Put my oem rotors and pads back on, perfectly quiet.
Quick Reply: 02 camaro front end questions
