Should I flush my trans.?
I pulled my 98 ta out of storage yesterday and ran her over to the dealer for a oil change and tire rotation.
I got the car from a buddy last summer so the only service history I have is from the past 4yr's or so he owned it.
I inquired with the service manager about changing the trans. filter since doing a flush scares me on such a high mileage(187k) drive train and no clue if it has been done before. He informed me that he has the same car and that they have no filter just a screen so dropping the pan is a waste of $$$
Ok make sense, He suggested I do a full flush and refill with synthetic fluid and the trans. will be fine. My major concern is who knows when it was last done if ever and I'm worried that the flush may release/clean out the crap that's been...well simply keeping everything working.
So any thoughts?
Thanks Guys
So any thoughts?
Thanks Guys
He is an idiot. There is a filter. That high mileage honestly I would not.
I thought about it on my 107k Z28, but decided to drop the pan, replace the filter, and fill back up. After dropping the pan I had ALOT of metal shavings saved on the magnet.
If I went the full flush/fill, I would of been asking for more harm than good and would probably be sidelined for the year for a trans rebuild.
I went with a AC/Delco filter (came with a cork gasket but opted out) and Felpro gasket w/Dexron VI (formally Dexon 3)
Just make sure if you do drop the pan and refill. Do not over tighten the pan bolts.
It is a filter,not a screen. In 2004 when I did a pan drop,everything was clean and fluid looked good. I installed a TCI finned deep pan with the supplied rubber gasket,no leaks yet. The TCI pan has a drain plug to facilitate draining. I wouldn't recommend a deep pan for a lowered car as speed bumps can be a problem.
Thanks guys!
Grrrrr. I don't have to be back at work until Thurs., So if time I have time tomorrow I'm going to go back and talk him.
Anybody have the links for the shop manual's. I had the PDF's but my old laptop hard drive crashed and was unrecoverable.
Wow sorry but thats ******* ignorant...
So this guy at the Dealership said the Transmission does not have a filter AND wants to flush a high mileage transmission and you still want to go back to him, ok that sounds like a good idea let us know how it works out for you.
LS1Tech Administrator
Received 1,467 Likes
First off, tell the service manager to look up GM part number 24236799. This is a trans filter kit for a 4L60E (trans that is in your car). He would know this if he bothered to take the time to look it up, like a professional should.
Secondly, like all the others have said, if it's never been flushed before then don't do one now at that mileage; drop the pan and change the filter and that's it.
Here is an official GM report on DexVI:
http://www.imakenews.com/lng/e_article000384801.cfm
Yeah dex6 is not dex3. I tried getting GM dex3 when I did my stall a few years ago but they told me they switched to dex6 at GM. So when I had my trans out I stood it up on its tail to get all the fluid out that I could. Refilled with about 10 new qrts of dex6. I didnt know we cant switch back though. I have topped it off with a little dex3 at times. No issues.
I ran an oil change shop years ago. I told people with high mileage not to flush the trans. One customer really wanted it done. Made him sign a waiver that we were not responsible for damage. Came back 3 days later bitching his trans blew. Had around the same mileage. Don't do It
But for a 4L60E, or any other trans that came with DexIII, or even old DexII transmissions, you can use either the DexIII "equivalent" (GM no longer issues licensing for DexIII, so most suppliers just call it Dex/Merc or DexIII equivalent now) or the new DexVI as it is backward compatible.
Thanks Guys. I do have a trans. shop that has a great rep. I've dealt with before so I'm going to give them a call and have them just change the filter..
What really ticks me off is in the back of my head I knew he was way wrong. I've always felt the guy has been honest with me in the past
He knows I do most of my own repairs so I'm surprised he tried to play me or was just that ignorant
I'll keep using them for lube & rotation but will have a talk with him on my next visit
Yea thats what I meant to say in my previous post lol. I am retarded at times.
Just do the filter yourself. Jack the car up, loosen the bolts without fully taking the pan off. Let it drain. Loosen more, drain, and fully take out all the bolts for 3/4 sides. Slowly let the pan at an angle to drain .
Once thats done. Just yank the filter on out, replace, reverse steps and do not over tighten the bolts. Very easy. If you can turn a wrench you can change the filter.
When I dropped the pan/filter I let it drain for a little bit because I had to pick up some parts, when I got back it wasn't dripping anymore.
