99 Z28 - Fuel Pressure Release
Old 04-04-2013, 05:45 PM
billscamaros's Avatar
Default 99 Z28 - Fuel Pressure Release
I want to change the fuel filter on my '99 Z28. Per my Haynes manual, I have to release the fuel pressure via the Shrader valve on the fuel rail.
So can I just put a rag under the valve and use a screwdriver to depress the valve to bleed off the pressure?
I see two ports in the fuel system.
Which one do I use to bleed off fuel pressure?
Thanks
Bill
Old 04-04-2013, 06:02 PM
AmDWs6's Avatar
the one on the fuel rail releases pressure .. so you can mount a gauge on it if you want but im not sure if it would work for what ur trying to do
Old 04-05-2013, 03:05 AM
_JB_'s Avatar
Screw off the black cap, put some rags under it and press the valve.
Old 04-05-2013, 07:42 AM
Thanks!
Old 04-05-2013, 11:02 AM
Got it done. The hardest part was unclipping the bracket that fits around the filter. JB - it was pretty easy to bleed the pressure off. Thanks again!
Quick Reply: 99 Z28 - Fuel Pressure Release
