Starter mount issue
Starter mount issue
I woke up got into the car turned the ignition a terrible screech came from under the car as my head hit the steering wheel in frustration....I thought I can fix this 1hr tops got under the car remove starter and than a few pieces of the starter mount fall off the block as I unscrew the loose bolts......the ear the the long bolt goes through is completely sheared off my guess is the high torque......is their anyone that has a fix for this besides getting a new starter (which ive done)and for the record the mount on the starter is sheared aswell...?
There are several options, starter bridge, run truck starter with only long inside bolt, try having it welded...or use this as an excuse to build a LQ9 408!
Bridge
Thread Page 8 (posted by WS.SIX)
Bridge
Okay! my starter bridge has been installed not the most easiest of tasks especially without a lift infact its a PITA!
You do have to trim the side of the block off flush and than at angle and the two bell housing bolts are near impossible to put back in an once you do pray you have smaller hands and skinny arms to fandangle you army past the collector into the space below the #8 spark plug location.
Did anyone else have as much of an issue trying to tightent the upper bell housing bolt mine isnt completely snugged as I had to use a mini wrench any tips and no theirs no room for a socket and a universal or ratchet setup....
Is running the truck starter(two long bolts) with only long inside bolt really an option. My starter broke off, just like most of the pics here, there is a little bit of aluminum that didn't break that I could use a square nut behind it to give some clamping force on the outside bolt.
The three pics are from my car. The first two are after it happened this past friday, the last is from when it first happened end of September 2013
I tried it with a new starter with that hope and it just cracked the new starter ....your options are .....replace the block, TIG weld the ear back on, or get the starter bridge .........and its a PITA to fit the truck starter in with the bridge. Also youll need to cut the remaining piece of the ear off the block in order for the bridge to fit because it takes the place of the original hole ....also if u intend to upgrade your ground now would be the time to do it since it sits on the block behind the starter :/
Im still using my truck starter that was suggest to me off of ebay with the starter bridge so its been going strong for over a year now.....and i did as suggested use both long bolts.......if your going to use the starter bridge youll need to sawzall the rest of the broken ear off the bridge fits in the prexisting hole and its a PITA to do it while the car is on jack stands i dont care what the guy says its not as easy or as quick as you think my turn around frustration time was 8hrs maybe it was me maybe it was the bolts not lining up right itd be a cake walk if u have the motor/trans out at the same time .
switch the short bolt out to a long bolt and replace your starter with a truck one I think its for an s10 it has more meat on the housing and check the torque specs and make sure their not loose ....loose and short bolt is the primary cause
