Ac compressor not kicking on
Old 05-01-2013, 08:35 AM
cancam99ss's Avatar
Default Ac compressor not kicking on
Hey guys about one month ago my ac was blowing cold, now the ac is blowing but not cold at all. I noticed the revs weren't going up as it normally did in the past so uncheck under the hood and realized the compressor wasn't even cold. I tried throwing some freeon in their but nothing happened...
Any thoughts
Old 05-01-2013, 10:29 AM
LS6427's Avatar
If the refrigerant is full and normal pressure......I'd say the compressor took a dump. Maybe inside the compressor has failed.
Old 05-01-2013, 10:49 AM
alexus6798's Avatar
Compressor is probably gone. Mine did the exact same thing. One day cold and then nothing. Good thing I purchased an extended warranty when I got my car. It was $1500+ to replace at dealership.
Old 05-05-2013, 05:56 PM
Dangro83's Avatar
Mine only blew cold air when driving... Hot when stopped.. Few days later nothing
Old 05-05-2013, 06:35 PM
superlazy's Avatar
Could be the belt, clutch went bad, loose connection.
Old 05-06-2013, 01:38 AM
Alex L.'s Avatar
This happens to me occasionally and I have to put in 2 bottles of freon in it. One does not do the trick but the 2nd one usually does. That's my routine anyhow.
Old 05-06-2013, 08:35 AM
FiredUpZ28's Avatar
Assuming its full of charge (not moisture and air). You can turn the A/C control on and ground the pressure switch briefly and it should come on. Check fuses n swap relays too thats a simple thing to check. Otherwise check for 12v and ground at the compressor connector with the A/C commanded on.
I personally dont condone adding R134a via the cans. I know its cheap, and A/C service is not. But the BEST way to charge A/C is to vacuum it all out and recharge it. I like to add an oz of dye while recharging just incase I have a slow leak. Putting the system under a vacuum before charging removes all residual moisture and most of the contaminents that can cause A/C failure. Plus it makes sure you have ONLY refrigerant (and oil) in the system.
Holy ****. I work at a dealer and even if the compressor was 5-800 bucks thats a LOT. It only pays 0.9 hours in ALLdata not counting recharge! Are you sure that was JUST for diagnosis, compressor, and recharge???
Old 05-06-2013, 08:53 AM
alexus6798's Avatar
Yeah, it was mostly in parts. The compressor was $775.50. Labor was $437. They did replace the orifice tube, accumulator, new seals, and the high side line though.
Old 05-07-2013, 07:36 PM
Homeless2bNY's Avatar
swap the AC relay first and see what happens.
disconnect the connector to compressor and give it power,
make sure clutch inguages.
then do it while car is running and see if it gets cold inside.
if it does, that means all mechanical is GOOD,
and you have a electrical issue
Quick Reply: Ac compressor not kicking on
