MAP P0106 Problem
Old 05-01-2013, 01:02 PM
Gordon0652's Avatar
Default MAP P0106 Problem
Hello,
My G8 has mostly sat during winter and now I have been driving it. Check engine light comes on with a P0106 light ONLY city driving, not highway. I have replaced the sensor and the same thing keeps happening. As soon as the light comes on the idle drops then speeds up then drops until a stall. NOTING has been changed with the car - and just checked the idle pressure and it is around 49-51kpa.
Thanks...
Old 05-01-2013, 09:00 PM
dreww's Avatar
Try cleaning the harness to the MAP
Old 05-02-2013, 01:58 PM
Gordon0652's Avatar
I re-flashed the ECM with the same tune, and back to normal, maybe a bug?
Old 05-27-2013, 12:11 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
Im getting the same code since I dropped my idle rpm back down to 725. For me, I wonder if the issue is with the blower, cam, and low rpm that the map sensor is fluctuating too much and causing issues.
Old 05-27-2013, 07:09 PM
Gordon0652's Avatar
My idle was also lowered! Reflash, it will work..!
Quick Reply: MAP P0106 Problem
