Check Gauges light flickers... 98' Camaro SS
Hello,
I have a 98' Camaro SS with 150K miles and the "Check Gauges" light sometimes flickers on the dash. All gauges are reading correctly. Last time I checked with a voltmeter the car was charging correctly. I also just replaced the serpintine belt tensioner and the concern still intermittantly still happens...
Anybody have the fix for this????
Thanks!!!!
Thanks!!!!
LS1Tech Administrator
Received 1,492 Likes
Have you paid close attention to the gauges specifically when the light flickers? I know you mentioned that charging seemed to be fine, but have you watched the voltmeter at the moment that the light is flickering?
Also, is there any particular behavior that seems to make the light flicker, such as lugging engine/heavy accessory load/WOT/etc.?
