Help tracking down oil leak!!
Old 05-14-2013, 06:53 PM
USMC5811's Avatar
Default Help tracking down oil leak!!
My car has been dripping oil very slightly ever since i did my motor swap. there is oil on the bottom back side of the oil pan as well as a drip coming off of the bottom of the oil filter.
are these cars notorious for developing a leak in a certain area or is their anything i can do to see exactly where its coming from?
Old 05-14-2013, 09:41 PM
Homeless2bNY's Avatar
look around the oil pan gasket and above the filter there is a block
off plate for oil cooler.
also look up into the bellhousing as best you cand to check rear main and cover
Old 05-15-2013, 08:09 PM
FiredUpZ28's Avatar
Add oil dye and get a fluorescent light if you can.
Old 05-17-2013, 06:57 AM
USMC5811's Avatar
does autozone/advanced sell the oil dye? i've never seen that stuff before!
Old 05-17-2013, 10:03 AM
patSS/00's Avatar
Check torque on the pan bolts around the filter area that go up into the rear seal cover, there are 2 or 3 of them smaller than the other pan bolts, these can loosen up by themselves and cause a slow leak.
Old 05-17-2013, 11:26 AM
SWEET98SS's Avatar
Yes they sell the dye
Quick Reply: Help tracking down oil leak!!
