Ls1 tune-up
Old 05-20-2013, 10:34 AM
spydog's Avatar
Default Ls1 tune-up
hi i have a 1999 trans am LS1 stock and have had it this will be my 4th summer and i have never dun a tune up on it i have only put on 7K miles on it since i bought it. what would your recomend for a tune up plugs wires EXT. Brands? that car is mint but has 98K on it
Old 05-20-2013, 11:38 AM
Nicky98T/a's Avatar
when I buy a used car I'd do it just for the hell of it, the previous owner could have said they've done it but honestly you can never be sure. I also do that so I know what is in my car is approved for my liking. If you got some free time and you want to do I'd do it just be prepared for the hassle with cylinder #8
Old 05-20-2013, 12:25 PM
spydog's Avatar
what bran plugs and wires would u run
Old 05-20-2013, 12:36 PM
Nicky98T/a's Avatar
I run the oem acdelco iridium replacements with msd wires
Old 05-20-2013, 01:00 PM
spydog's Avatar
part # on the plugs?
Old 05-20-2013, 01:08 PM
Nicky98T/a's Avatar
Acdelco 41-110
Old 05-20-2013, 05:35 PM
snake_skinner93's Avatar
Same here. Just did mine the other night. I actually did all plugs & wires and never even had to remove the coils on the passenger side. My arms now look like a heard of cats have attacked me, lol. You WILL have to go underneath the car for that rear plug though. I'm now moving on to O2 sensors, knock senors, swapping in a LS6 Valley Cover, changing Oil Pressure Sending Unit (even though it doesn't need it. Prevenative Maintenance so to speak)...etc. I have a long way to go, but it'll sure feel good to have it completed.
Old 05-21-2013, 06:17 AM
spydog's Avatar
ok thank you i am between NGK iridums and ACDELCO iridums is one better than the other? NGK i can get for $6.72 per plug and the delco for $5.59 per plug
Old 05-21-2013, 06:28 AM
Nicky98T/a's Avatar
Delcos are ganna be with car came with stock oem quality sometimes is best. NGK also makes a great plug either way I think you'll be satisfied just be sure to gap the plugs I think the spec is .040 (dont quote me on that) even if it says pre-gapped if the box gets thrown around in the parts store it'll throw off the gap
Old 05-21-2013, 07:24 AM
spydog's Avatar
ok thank you anyone els know the gap i should be at?
Old 05-21-2013, 07:53 AM
Nicky98T/a's Avatar
I looked it up in my parts store computer 98s gap was .050 everything after was .040
Old 05-21-2013, 10:31 AM
spydog's Avatar
i have a 1999
Old 05-21-2013, 10:32 AM
spydog's Avatar
http://www.ws6project.com/user_stor/...ctor-wire-set/
are these good wires
Old 05-21-2013, 01:20 PM
eteller's Avatar
I went with MSD wires and NGK TR5 plugs. IF I had to do it over I would have chose iridiums for the fact you don't have to change them as much. Using my friend a ASE Master Mechanic with skinny arms and his lift it still took us forever on the passenger side. Between that and swapping my intake my arms have looked like I lost a battle to some cats all spring long.
Old 05-21-2013, 02:36 PM
spydog's Avatar
i ordered the MSD 8.5mm Super Conductor Wire Set i got them for $62 know i just have to deside on NGK or ACDELCO iridums???
Quick Reply: Ls1 tune-up
