Cold starts perfect, Warm starts stalling.
Old 05-22-2013, 04:16 AM
Sunset Vette 05's Avatar
Default Cold starts perfect, Warm starts stalling.
Hey guys, I've got an 01 ws6 with a cam (232/236 .575 .578 on 112 lsa). Cold starts it starts perfect, but when the car is warmed up, the RPMs will flutter and stall, or come verrry close to stalling. It's been doing this for a few months, the cam is not recently installed. I had it recently tuned, hoping that would clean it up but it didn't. Any ideas? From what I've read it could possibly be the IAC? Anyone else having a similar issue?
Thanks in advance!
Old 05-22-2013, 01:03 PM
great421's Avatar
Cold = Open Loop
Warm = Closed Loop with O2 Sensor Input
If a vehicle has issues once it has warmed up, then look at those inputs the PCM uses, such as (in this order) the: pre-cat O2 sensors, post-cat O2 sensors, IAT sensor, Coolant Temp sensor, MAP & MAF sensors.
Good Luck!
Old 05-22-2013, 04:28 PM
Homeless2bNY's Avatar
check engine light on?
what code is in there?
might be a crank sensor. P0335
after it warms up and starts acting up, shut it off and pour water
on the pass side rear of engine where sensor is from hose for couple min
to cool sensor.
start it up and see how it runs. that's just a trick to check if heat is a issue
Old 05-22-2013, 08:40 PM
LS6427's Avatar
to cool sensor.
....BE CAREFUL.....pouring cool water on hot aluminum WARPS the aluminum.
Old 05-22-2013, 08:42 PM
LS6427's Avatar
Thanks in advance!
Could be a weak battery. Have it checked for a short.
Old 05-23-2013, 07:41 AM
flattusmaximus78's Avatar
Tuner gave no input on any of this?
Quick Reply: Cold starts perfect, Warm starts stalling.
