Fuel Inj cleaning in Pics
Old 05-23-2013, 06:31 PM
sjsingle1's Avatar
Default Fuel Inj cleaning in Pics
Those bottles of fuel injection cleaner that cost from 2.99 to 20.99 only do sooooo much !!!!
Best to clean your injectors like a pro ................follow along
can of 3M inj cleaner PN 08956 and 3M FI cleaner hose PN 08917
Old 05-23-2013, 06:32 PM
sjsingle1's Avatar
first find your fuel pump fuse
sjsingle1's Avatar
sjsingle1's Avatar
then remove it
Old 05-23-2013, 06:33 PM
sjsingle1's Avatar
find the cap on the fuel rail
sjsingle1's Avatar
Old 05-23-2013, 06:34 PM
sjsingle1's Avatar
might still be pressure in the rail so relieve it
Old 05-23-2013, 06:35 PM
sjsingle1's Avatar
attach the FI hose to the fuel rail
sjsingle1's Avatar
sjsingle1's Avatar
Old 05-23-2013, 06:36 PM
sjsingle1's Avatar
put the adapter on the can of cleaner
Old 05-23-2013, 06:37 PM
sjsingle1's Avatar
attach the can to the hose
Old 05-23-2013, 06:38 PM
sjsingle1's Avatar
switch the valve on and start the car......hold can upside down with the engine at idle......hold it til the can is empty.....about 5 min
Old 05-23-2013, 06:39 PM
sjsingle1's Avatar
throw empty can away and enjoy the bliss of a smooth idle from clean injectors
Old 05-23-2013, 11:36 PM
LS6427's Avatar
Sweet.......easy and straight forward.
But how does it idle with the fuel pump fuse pulled out? Or did you just not mention to pop it back in after the bottle is ready to discharge into the rail....?
I think I'll give this a try....easy and cheap.
Old 05-24-2013, 12:52 AM
RJDio's Avatar
thanks! I'm going to put this on my "to do" list
Old 05-24-2013, 02:15 AM
sjsingle1's Avatar
you pull the fuel pump fuse so the fuel pump will not operate while the cleaning process is occurring.........the FI cleaner contains fuel to run the car at an idle speed as well as the concentrated cleaners.......when done with the cleaning replace the fuse so the pump will operate normally
Old 05-24-2013, 02:27 AM
sjsingle1's Avatar
update.......apparently 3M has changed this hose since i bought it.....mine is a 1 piece hose and now it is 2 separate pieces.....hose 8838 with the angled end adapter 8917
Old 05-24-2013, 10:51 AM
Crispy's Avatar
The cleaner is pretty cheap but I'm seeing the hose for $90 at the low end and. Was this worth it in your opinion? How many miles are on your T/A?
Old 05-24-2013, 11:22 AM
sjsingle1's Avatar
i have seen the hose for cheaper....and i bought mine at NAPA for 40$.........if you figure you pay 100$ to have a shop do this.......how much did you save?
and after a cleaning you sure DO feel a difference.......i use the pour in the tank cleaners all the time and they do not compare to this
Quick Reply: Fuel Inj cleaning in Pics
