LS1 Strange Instrument Cluster Issues
Old 06-26-2013, 01:36 PM
zrultima's Avatar
Default LS1 Strange Instrument Cluster Issues
Well I just ran into another problem with my F body Trans Am I had been driving the bird about a week ago today. I was driving around 8:00 pm when suddenly my instrument cluster light turn off while driving. I analyzed it a bit further and notice that all my tachs , speedo, odo, temp, where all working as they should. My tach had remain on and was still calculating the mileage. I thought the light has justg blown out and cause it to turn off.
The Next day at my gf house we were going to go fishing so I walked up to it as normal turned it on the first crank I then noticed none of my tachs work not a single one and the instrument cluster light still didnt work. I took it to a local mechanic he found that 3 fusses had blown one on the dash and 2 inside the engine bay. He replaced all 3 then my tach and everything else starting working fine as it should. I took it to the lake and shut her off.
A few hours later I went back to the car turned her on cranked right up and
then now only the oil pressure and the alternator are working nothing else is not even the hatch release I checked the fuses they all seem to be fine. Anybody know where I should start?
Old 06-27-2013, 06:38 AM
zrultima's Avatar
Any ideas anyone
Old 06-27-2013, 10:20 AM
xxrillixx's Avatar
Sounds like its just the fuses, question is why are they blowing? Have you checked all of your grounds? Do you have any aftermarket wiring / stereo?
Old 06-28-2013, 12:32 AM
notnilc20's Avatar
Same thing happened to me and i found it to be the fuse on drivers side dash labelled PWR ACCY.
15 A fuse. But like other member said, why are you blowing these fuses?
Old 06-28-2013, 07:31 AM
zrultima's Avatar
No aftermarket wiring and it seems that all the fuses are fine they all been checked
Old 06-28-2013, 07:34 AM
zrultima's Avatar
They only blew once just once that they blew they were changed out car was working fine but after turning it off it happen again buit no blown fuses
Old 06-29-2013, 11:15 AM
zrultima's Avatar
When hitting the trunk latch switch you can hear the relay clivking on but the hatch wont come up when I first took it to the shop it was doing the same exact thing after a few fuses replace it worked fine... I turn off the car and the
Old 06-29-2013, 11:17 AM
zrultima's Avatar
trunk latch stopped working thats why I dont think its the cluster
Old 06-29-2013, 08:44 PM
zrultima's Avatar
Anyone?
Old 07-01-2013, 10:18 AM
zrultima's Avatar
Hey buddy Thank you for the suggestion to keep you guys uptaed I replaced all my fuses and still didnt work so I reset the computer and batter then checked fuses again the pwr AccY blew. Replaced it and everything works except the backlight on the instrument cluster and taillight
Old 07-05-2013, 07:59 AM
zrultima's Avatar
Everything works great except the backlight on the instrument cluster so I am thinking it would be the dimmer switch any thoughts?
Old 07-09-2013, 07:56 AM
zrultima's Avatar
Anyone Im still chasing this I been trying to search the forums but no one with my particular problem and I cant seem to find the switch either. I work for NApa anyh other names it might be called?? my Fog light, Running lights, and dash light dont come on
Old 07-09-2013, 08:44 AM
PontiacFan's Avatar
I have had the same problem & haven't found a solution yet, ...
The Dimmer/Headlight switch combo unit can be found on Ebay.
Mine started when my dimmer switch overheated & burnt up, ...
Put a new one in it & now the backlighting for the gauge cluster does not come on.
But the dimmer switch somewhat works because the lights on the steering wheel will change with movement of the dimmer.
Old 07-09-2013, 10:47 AM
zrultima's Avatar
Well eres the part # I am pulling up at NAPA would these work
http://www.napaonline.com/Catalog/Re...0060%2b2060012
Old 07-10-2013, 09:01 AM
PontiacFan's Avatar
Here's what happened to my switch, ...
(And good luck with that NAPA link, ..., doesn't look like this.)
Attached Thumbnails LS1 Strange Instrument Cluster Issues-switch_1.jpg   LS1 Strange Instrument Cluster Issues-switch_2.jpg
Old 07-11-2013, 12:30 PM
zrultima's Avatar
Seems no one carries it huge pain in the *** lol
Old 07-13-2013, 07:10 PM
xBrian's Avatar
i don't mean to be a smartass, but have you adjusted the dial on that switch? it could be turned all the way down, causing the lights to be dimmed completely. Try turning it up to see if it changes, and then when you keep turning, it should activate the interior lights.... Does that all work?
Old 07-15-2013, 08:00 AM
zrultima's Avatar
No dont worry thats the first thing I did =D but I finally got an answer I went ahead and tried to remove the switch to take it to a junkyard. As I was removig the harness to the switch I noticed some lose wiring I used electric Cleaner and electric tape to get the wiring nice and tight. I placed it back in and changed the fuse and wala it worked thanks for the help guys
Quick Reply: LS1 Strange Instrument Cluster Issues
