Will this work to test oil pressure gauge?
Im trying to test my oil pressure gauge in the cluster. My car is a 98 Z and I have a spare cluster from a 97 Z that i want to try swapping in. Will the oil pressure gauge read on the 97 cluster if i plug it into my 98? I dont care about any of the other gauges. Any input would be appreciated
Save the manuals!
Seems like a hard way to go about it, especially since the cluster gauge isn't very accurate. The needle on the actual gauge may have even moved on you.
Have you tried confirming the reading with an OBDII scanner? Its hard to believe that the cluster gauge would go bad.
Save the manuals!
What's the problem?
A few of us have had jumpy needles on the gauges and it seems the issue was the oil pressure sending unit: https://ls1tech.com/forums/general-m...ding-unit.html
