Cleaning LS6 intake before putting it on
Hey guys, I just picked up a used ls6 intake of an 02 trans am yesterday. I'll be installing these with my TSP longtubes, which are on back order till late July according to speed inc.
So, on inspecting my intake, the runners are caked up with some oil crud. I did a couple searches on how to clean them and started with some simple green and warm water. That worked a little bit with some rubbing with a towel. However there is some more cake up where I cant reach. Other threads said brake cleaner and or throttle body cleaner. I'm a little hesitant to use those on a plastic intake. What do you think? Think its even worth to clean it since oil will just build up again?
Use a long screwdriver, or bent metal coat hanger to reach it and break it loose, then blast it out with either a garden hose nozzle or better yet take it to a quarter machine car wash and blast it out with high pressure soapy water.
IMO, I wouldn't use brake clean, but spray can carb cleaner is safe to use.
Yes, it worth it to clean it out good!
Take the intake and completely submerge it into some kind of tub or bucket....use 75% Formula 88 from Home Depot and 25% water. Let it sit over night. Then with the brush the next day go to work while its still in the tub of degreaser. Clean the runners and inside the intake.
Then rinse the hell out of it with water....should be good as brand new after that.
Make sure it's a good toilet bowl brush that doesn't shed its bristles....you don't want them left behind in there.
