dash & foot defroster work together or is something butchered?
I needed to turn on my dash defroster & when I turned the **** to the top defroster setting only and air blows thru the top & botom plus both icons light up. Is this factory or did my wonderful p/o butcher something? He had the top/t/c surround glued back on so he was in there for some reason. Any common reason someone would pull this area apart? Thanks people.
These are controlled by little vacuum hoses that attach to the back of the control ****. It is possible that one of these little tubes is disconnected or some other issue.
The faceplate that covers the radio and heater controls just pops off, it is held in by a couple little clips. Use a small flat screwdriver and carefully remove it. Then you will see a couple of bolts or screws that hold the heater/ac control unit in.
I would pull the heater/ac control unit out and look at the rear connections to the ****.
Defrost automatically turns on the A/C if thats what you mean by "icons lighting up". And its normal for air to bleed out of the floor when its on defrost, and vice versa.
