Should I be worried?
So i went to Wegmans last night and decided to take the Camaro. I let her warm up a few minutes, I pull out of the driveway and pull up to the stop sign. As i start to go the motor started to lightly spudder for a few seconds and once i start driving its fine. It also happened this morning also. Does anybody have any thoughts? The throttle body and MAF are clean, i do have about 1/4 tank of gas left in the tank.
LS1Tech Administrator
Received 1,486 Likes
Not really enough to go on here.
Do you have a scanner?
It would be helpful to check for pending codes, and get live O2, fuel trim and misfire data when the issue is happening.
