Cheap Radiator Fix?
Cheap Radiator Fix?
I have a 2000 Transam. Just took it to a local car shop for my AC not blowing cold. Getting it fixed cause I have it under warrantee. Turns out there is also a crack in the radiator. Been looking on ebay for one. Recommendations anyone? Thanks!
Yes.....you must put an LT1 radiator in. It's a free way to have a little better cooling ability up there.
All you have to do is cap off one extra port that it comes with. Put a 6" inch pice of heater hose on it with a clamp, then put a brass plug in the other end with a clamp on it. It makes a great flush/drain port. Wile you're at the auto parts store, have the guy put that little hose, clamps and brass plug together for you. Probably cost $7.00.
