Help with power window motor replacement
I've searched and watched videos on replacing the motor.
Every one I've seen,the window is in the up position.
Mine is stuck in the nearly full down position.
Whats the smartest way to remove the window,regulator, motor etc.
I'm guessing without the window up there is not enough room to pull the motor.
Tips for removing the whole assembly appreciated.
Thanks.
Thanks.
