Power Steering Problem???
So recently I replaced my steering rack because it was leaking. I connected the p/s lines back into the rack and proceeded with the bleeding process. I put the front end up in the air, started the car, and turn the steering wheel from lock to lock about 20 times. I noticed a few small bubbles coming out, until it stopped.
Then I lowered the car back down and noticed it was really hard to turn the steering wheel sitting at idle. Once I got driving/moving it wasn't too bad. Drove it to the alignment shop to see if it would help because I knew the setting were off from replacing the rack.
Its still doing the same thing!?!?!?!.....almost rock solid to turn the steering wheel. I tried the bleeding process again but no more air was coming up through the reservoir. I checked for leaks (besides the oil pan leak) and the rack seems dry, the alternator is spot clean so I assume no dripping from any lines to the pump.
So....could my p/s pump be going bad? What do you guys think it could be?
P.S. It steers fine when normal driving. Its only when at a stand still at idle, or when I'm coming up to a road to make a fast/hard turn it then does it also.
Take the top off the reservoir so you can see the fluid sitting in it.
Point the line down into a catch pan.
Have a friend start the engine and see if the fluid shoots out.........but only for a couple seconds.
That will tell you if the pump is working.
Disconnect the line that's attached to the bottom of the reservoir...low pressure return line.
