Abs inop
Abs inop
Had this light coming on and off for a long time. A couple years ago I replaced the FR hub and it went away for a few months (though that fixed it) but then came back. A couple months ago I had a friend hook it up to a GM Tech II to see what was going on and apparently it was the ABS module, which I then replaced. Now, the light is back on. I don't have access to a GM Tech II, but am unsure how to best proceed in getting this finally narrowed down the actual culprit so that I can replace it.
Any ingenious ideas from anyone?
I found someone to scan it for me and it's throwing another code for the FR hub, which was the one I originally replaced with a used hub from another vehicle. I did replace the ABS module with a used one as well.
When my light isn't on, I usually get the flutter and then the light comes on as well.
replace hub with new one imo. And check wiring of the ABS module, mine used to come on and off and I found a bad wire.
But replace the hub with a new one IMO. If that doesnt fix it, return it.
