2001 z28 brake lights and dash light out help please
Hello, just joined today, i own a blk 2001 z28 shes been pretty good to me but now am experiencing a headach. Ok so today i take her in to get a light bulb charged at a jiffy lobe. It was my driver side front blinker, he goes for a new bulb pops it in, then he shows me that now the other side is blown out and says its a fuse. So i think ok, no big deal, well when its gettingdark around here i hop in the car and notice my brake light and dash light thatgows up my gauges is completely out. When i step on brake it lights up, when i turn on the light switch it only turns on the headlights, am a newbie can you guys please point me in the right direction
It's not mine! woo hoo!
Just to be sure we understand you correctly, are you saying everything was fine until Jiffy Lube simply changed the driver-front signal bulb in the bumper?
While I am not familiar with the symptoms you're explaining, this is how I'd try to diagnose the issue:
Check all fuses
Check the installation of the new bulb -- did the tech bump something?
Ensure the dimmer switch is operating properly
Lastly, I'd stay away from Jiffy Lube
Check all fuses
Not trying to be rude, I just don't know how anyone can help you if you can't change a light bulb.
I had this issue in my TA last year and took it to the dealer they had the car for three days and said their was nothing they could do and didn't feel uncomfortable working on it.....I got in and fired it up everything worked ....Before I took it I replace the dimmer/ light switch nothing....replaced fuses because every time I turned the lights on i blew a fuse. The mechanic said he just checked the grounds andput it on the scanner >.< so I assume it was a ground
