ls6 crankshaft sensor wiring help
Old 11-08-2013, 10:54 PM
7beast's Avatar
Default ls6 crankshaft sensor wiring help
Hey fellas just a quick run down before I ask the question. This is an ls6 motor going into my 72 camaro, my stand alone harness is from shwanke shortblocks. I have everything wired up and iam getting it to turn over but get no fire. I checkedand I have 12v going to each coil. My guess would automatically be crank sensor but iam positive that's good. Then I checked the colors on my crank sensor connector and according to info I looked up it seems like my ckp signal(blue and white) on pin "A" and 12v (green) on pin "C" wire are crossed. Am I correct?? Someone please help. Iam quite new to these ls motors so please bare with me.. Here's a pic
Old 11-08-2013, 10:55 PM
7beast's Avatar
And here is info I found
Old 11-16-2013, 09:55 PM
7beast's Avatar
Anyone?
Old 11-23-2013, 11:08 PM
7beast's Avatar
I have been told that the connector was wired this way because the harness was set up for an 8.1 motor with cam sensor in front. Can anyone verify this? I just seen that terminals A and C on my cam sensor connector were also crossed. Can any one please verify this and is all I have to do is switch the wires back the way they should go?
Old 11-25-2013, 12:38 AM
joecar's Avatar
All my wiring diagrams show same as what you show in post #2...
have you tried uncrossing A and C...?
Old 11-25-2013, 01:20 PM
7beast's Avatar
Yes sir yesterday I finally had a chance to uncross them but the car still wont start. And still not getting any spark. Maybe bad crank sensor
Old 11-25-2013, 06:41 PM
joecar's Avatar
Before condemning the crank sensor, measure it resistance; and then while cranking see if you get an AC voltage from it using a DMM (something like 0.5-1.0 VAC).
Quick Reply: ls6 crankshaft sensor wiring help
