Won't Crank-No dashlights-headlights work.
Old 11-11-2013, 08:53 AM
Ndb270's Avatar
Exclamation Won't Crank-No dashlights-headlights work.
headlights work, door chimes,
But no dash or radio lights and will not crank. no clicking just will not crank.
Changed ignition and starter relay fuses and nothing still.
Any suggestions?
Old 11-11-2013, 10:04 AM
lt1pwr1's Avatar
Any suggestions?
Check all your fuses. I can't recall exactly but I think there is an ECM fuse or something similar which will cause your symptoms. Best thing to do first is to make sure there are no blown fuses though.
Old 03-12-2014, 09:08 AM
jt_2002_ta's Avatar
Did this ever get resolved? I have the exact same symptoms
Old 03-14-2014, 08:07 AM
ALT-F13's Avatar
check gauge cluster fuse - i had the exact same problem and traced it to blown fuse
Old 03-20-2014, 01:03 PM
Jrclayton's Avatar
Cluster fuse on my 99 firebird blew and i had these symptoms. The fuse is called IP Dimmer. its a fuse on this inside f the car not under the hood. Mine was a 5amp fuse. Replaced it with a 25amp and havnt had an issue. Let me know if this helps.
Fuse Usage
IP DIMMER Door Illumination Lamp
(Right-Hand, Left-Hand),
Headlamp Switch, Fog Lamp
Switch, Instrument Cluster, HVAC
Control Assembly, PRNDL
Illumination Lamp, Ashtray Lamp,
Radio, Rear Window Defogger
Switch/Timer, Traction Control
Switch (TCS), Convertible
Top Switch
Quick Reply: Won't Crank-No dashlights-headlights work.
