2002 Camaro SS bouncing oil pressure gauge
Stock car with an oil pressure gauge that bounces when off the throttle and car completely idles. Notice oil pressure rises with rpm like normal then below 10mph it goes hay wire. I've heard this is a common problem any tips before I start investigating tomorrow?
http://youtu.be/n6kseHxYgZY
Yea my oil pressure gauge seems to have a mind of its own I was told dont worry about it. If you find out a reason as to why yours is doing it please do tell. Mine goes down while on throttle then goes up when off the throttle or visa versa cant remember i dont watch it as much after i was told dont worry about it lol
Save the manuals!
It's common for this to happen when the Oil Pressure sensor goes. BTW: It's a real pain to replace. https://ls1tech.com/forums/general-m...ding-unit.html
I consider taking off the intake a ROYAL PIA, but most of you on here (NOT in this particular thread, but on this site/forum) talk like it is something you do every other week, blindfolded, with one hand tied behind your backs, in your sleep, in a half hour or less.
Save the manuals!
Well you don't have to take the intake off to do this. The catch is that you need to reach under the cowl and behind the intake to switch the thing out. You can only do it with one hand, you can't see your work. So, I guess that's a lot like being blindfolded, with one hand???
lol I agree there is no way people are doing this under 30 minutes its highly improbable that can happen. to tight of a place, cant see what your doing, only being able to do it with one hand, the list goes on. Also even with 2 people taking off the intake is at least a 30 minute job IMO just do to the clearances a lone. you really don't have enough space, I mean you and the other person has to lift up the back 2 bolts high enough to pull it out but not too high because they will get stuck under the cowl. So going with a bigger intake like a 102mm Fast LSx i can see it taking forever to put that in.
Save the manuals!
These owners must have baby girl hands then, as I've tried that with the cam position sensor AND the oil pressure switch, and I could not get anywhere NEAR far enough (or deep enough) back there to even feel the pigtails/connectors for these, let alone actually get to the bolt and get the socket over the switch/sensor.
