A/C and Heat Blower will only work for about five seconds
my a/c and heat will only blow for about 5-10 seconds then it shuts off do you think its a bad relay or resistor? the relay is up under the console on the passenger side right??
OP -
I just replaced my blower motor, after fighting with it for a while.
If you drop the lower trim cover below the glovebox door, you'll see the blower motor in the RH corner close to the firewall. There is a two pin connector (B+ and GND) that powers the blower. If you wiggle (with the HVAC controls on "HI") the connector and the blower functions, but then slows or stops completely after a short period of time, (Logically) you would assume a poor electrical connection, but you might be wrong. If the blower motor is dying, one of the symptoms is intermittent failure.
If your two-pin connector looks corrosion free, then the blower could be at fault. My new unit (from RockAuto) cost about $50.
Good luck!
Good luck!
