Power steering fluid leak (help)
Old 03-11-2014, 04:51 PM
Alberto v05's Avatar
Default Power steering fluid leak (help)
Ls1 98 Camaro power steering keeps leaking i gotta keep refilling it it's like gas once low pour more lol. I got under the vehicle to try to pin point where it's coming it was hard to pin point exactly? It looked like somewhere under by the k member looks like a hell of a job to fix but got to get it done it's my daily drive. Thanks.
Old 03-11-2014, 05:17 PM
M4N14C's Avatar
Pics? Most likely it's the PS high pressure hose. I had the same problem, replaced the hose and no more leaks:
https://ls1tech.com/forums/general-m...ring-leak.html
Old 03-11-2014, 06:38 PM
LS6427's Avatar
If its the high pressure hose you're in luck......it's cheap and it takes 15 minutes to change.
Old 03-11-2014, 07:42 PM
dailydriver's Avatar
Yes, unlike a whole new rack which is ~$150.00 at a minimum, and a pain to do with the required re-alignment/partial engine lift/etc..
Old 03-13-2014, 02:55 PM
Well i'ma change that hose hopefully it solves the problem other wise it's gonna be a job to fix
Thanks guys i wanted to change the hose from day one but i wanted to see if there was more to it??
Old 03-14-2014, 07:11 AM
Save the manuals!
wssix99's Avatar
Do you have a pool of fluid under the car? Did your car come with a P/S cooler?
Old 04-19-2014, 12:20 AM
joseandy's Avatar
Any updates? I also have a power steering leak which i have to refill every week or so..
Old 04-21-2014, 07:16 PM
mr.haha's Avatar
Unhappy
Same here got a leak. Puddles up under the pass side of my car. Looks like it's coming from the rubber/ plastic boot on the rack???? Any one???
Old 04-21-2014, 09:43 PM
M4N14C's Avatar
Look under your car at the high pressure hose. If it's dripping with fluid get yourself a replacement and you're set.
ACDelco 36-363170, Amazon has them for $26
Passenger side? Got any pics?
Quick Reply: Power steering fluid leak (help)
