window motor fell off
Sooo I guess I should of Loctited these bolts, the motor is just hanging now after inspecting what had happened. The bolts must of broke loose, should I be concerned with anything else? I have to get some new bolts at home depot and re install the motor. The window is up mostly at this point on its own.
I never EVER do just the motor. I do the whole regulator assembly with GM rivets and have NEVER EVER EVER EVER EVER had an issue. Your gonna need to take the regulator out now and rewind that big spring and bolt/rivet the motor back on. I like using rivets - for pretty much the entire reason you posted.
LS1Tech Administrator
Received 1,487 Likes
I've always done just the motor. Never had one come loose after all these years. I don't ever use the bolts that come with the motor though, they are too short to use a decent lock washer and still get them on without a fight. So I go with bolts one step longer, use lock washers, and have no issues at all. I guess you could also use loctite for additional protection - I never did but it's probably a good idea.
Jesus, I figured I could just re attach the motor gear back on and be ok after bolting it back in. The window doesn't move its up atm and has very little play up or down if manually moving it.
