A/C stuck on defrost mode
ok so I pulled my motor and trans hooked everything back up replaced the stock intake with a fast in take and now im not getting any a/c from the other vents its staying in defrost mode the high and low settings work also the a/c heat setting work but changing it from any other mode wont work... I replaced the valve
and on this pic the hose is unhooked because therr is nowhere on the intake for it to go..do I cap it off?
last pic I hear people using a paper clip to jump the compressor which **** would it be should I still jump it?? but I a/c blows cold out of the defront and feet vents stuck what should I check now?? also I pulled the deck and selector control off and hose is still attached any advice thanks in advanced
