P0141, p0161, p0410 all related
Car sat all winter and got it out yesterday and ses light came on with these 3 codes. I hear the air pump turning on and off constantly as well not just at start up like normal.
Rear o2 heaters and air pump are what the codes read. So is my problem the o2s, the pump, or something else. Where should I start?
It's not mine! woo hoo!
Probably AIR check valve (the black circular things in the AIR pipes off the manifolds). They get clogged after time and will set multiple codes with the emissions. I had the same issue when I bought my car. I've got a couple extra valves I could send you if you'd want them. Just shoot me a PM
Ill give it a look this weekend though. Easy enough to check I guess. And many thanks for the generosity.
Ill post back this weekend
