Clunk from rear of car
I only noticed this over the last few weeks, but when my car gets hot (driving 20+ minutes), I sometimes have a "clunk" from the rear of the car when going slow and usually turning.
It doesn't happen all of the time and I can't even necessarily force it to happen, just sort of coax it to happen so it's making it difficult to figure out what it might be.
So far I'm thinking:
U-Joint worn out and making a noise
Ring/Pinion
Bearing issue
Brake issue
Any ideas?
Ring/Pinion
Bearing issue
Brake issue
Any ideas?
It's probably rear end noise. Could be the limited slip considering that you are turning when it happens. Mine started making clunking noises as it got older. Just jack up the rear and start twisting on the driveshaft. Should be able to hear what's going on a little more easily.
I would say the limited slip myself, mine had them same issues and when i took off the cover there were metal chunks everywhere as the cork screws in the diff had teeth missing
