oil pressure?
Old 05-15-2014, 01:55 PM
Camaro73's Avatar
Default oil pressure?
I have a 98 Trans am with 140k. The oil pressure at idle is at the line right before the red Mark but when I'm driving it goes up to 40 or more. Is that normal?
Old 05-15-2014, 02:13 PM
delrio_bird's Avatar
Im pretty sure a Bird rolls the same way but it sure doesn't sound normal. My car for instance, 95 Bird with 160k and an oil leak at the sensor......
From a cold start: 80
Few miles of driving (~10 miles): 45
Longer drives: 35
All at a redlight/standstill....mind you I have a leak. So I expect it to get better after that's fixed. I'd get yours checked out
Old 05-15-2014, 02:55 PM
Camaro73's Avatar
Longer drives: 35
Ya mine has no,leaks. But at a light it'll go down but driving it goes up.
Old 05-15-2014, 02:56 PM
Camaro73's Avatar
Car also isn't low on oil
Old 05-15-2014, 03:07 PM
Wheelman916's Avatar
My '95 Z reads a little low as well. Though I've heard many LT1s runs low psi regularly.
All readings taken from the in-dash gauge.
Cold idle: around 40
Cold driving: >50 (50 to 55)
Hot idle: 20-21
Hot driving: <40 (38 maybe)
When the RPM drops off idle to let the clutch out, it dips closer to the red, but as soon as the RPM climbs, pressure approaches 40. Dipstick shows a full oil pan.
I want to hook up a mechanical pressure gauge and see if the in-dash is accurate or not. I'd be happier with about 10 extra psi across the board.
Old 05-15-2014, 03:12 PM
Camaro73's Avatar
Hot idle: 20-21
That's almost exactly how mine is but at cold idle it's over 40 but warm idle is less than 40 at the Mark before red?
Old 05-15-2014, 03:20 PM
My next 2 theories then is a bad sensor or oil pump
Old 05-15-2014, 03:22 PM
Camaro73's Avatar
I hope not cause I don't have the money to fix it lol
Old 05-15-2014, 03:41 PM
Sensor is easy fix.
Old 05-15-2014, 03:52 PM
Camaro73's Avatar
Sensor is easy fix.
I wouldn't know where it's at, I've done a lot if research on these engines because of a swap I plan on doing in my Camaro but as far as experience with these engines I have 0
Old 05-20-2014, 03:28 PM
Jr.Samples's Avatar
Put some thicker oil in there like 10W40. As an engine wears there becomes more tolerance in the bearings where it builds from.
As oil warms it gets thinner causing lower pressure.
Good luck
Old 05-20-2014, 06:21 PM
dailydriver's Avatar
Sensor is easy fix.
IF you have 'baby hands'!! (It's behind the intake manifold, UNDER the cowl, with LOTS of plumbing/tubing/wiring harnesses in the way (if they were not all removed, like many on here do).
Old 05-27-2014, 02:11 AM
Camaro73's Avatar
Good luck
What about trying diesel oil for 1k miles or so to clean everything good?
Old 05-27-2014, 07:55 AM
chrysler kid's Avatar
The car is fine. As long as oil psi increases steadily during acceleration everything is good.
My 98 trans am had 20 psi warm idle but rose to 45 psi with rpms. As long as the pump is building pressure its ok to drive
Old 05-27-2014, 08:20 AM
1_MEANZ28's Avatar
like mentioned above..use thicker oil 10w40 should be good try if that does anything ,and replace oil pressure sending unit.if the issue is still there you will need to replace oil pump..been there done that
Old 05-28-2014, 04:51 PM
Is my engine the exception on here, as my hot idle pressure NEVER drops below 40 psi (at least according to the factory cluster gauge), and the ~2000 rpm, HOT, cruise/steady state pressure is never below ~55 psi, and WOT HOT pressure is never below ~60-65 psi???
Also, these pressure readings are ALL higher in the cold winter months.
Old 05-29-2014, 03:37 AM
_JB_'s Avatar
Mine runs very similar (never below 40psi idle and 58-60psi cruising) on 10w30 oil. Its been that way since I got it back in 05.
Old 05-30-2014, 02:10 PM
Camaro73's Avatar
So maybe it's the sensor?
Old 05-30-2014, 04:11 PM
1998 was the only year with an accurate analog gauge. 99+ is just a dummy meter. On the new camaro I believe oil pressure is 30psi at idle
Old 05-30-2014, 05:13 PM
Cole Train's Avatar
Mine when it's really warm it idles around 35 psi but it it fluctuates about 5 psi everytime my cam chops lol when i'm cruising it's around 55-60 psi.
Quick Reply: oil pressure?
