Alignment: 2 or 4 wheel?
Hey all, just needed to ask real quick before I make an appointment.
I just put Koni yellows on my 2001 SS... I opted for the lower perch, and did the hose mod.
Does the car only take a front end alignment? Or are there adjustments in the rear as well?
Thanks!
Thanks!
Well, as alignment goes, yes only the front wheels. You have a solid rear axle so no wheel alignment is needed in the rear. Having adj. aftermarket items linked to your rear is for adjusting the placement/angle of the rear end.
It's not mine! woo hoo!
As mentioned above, unless one has adjustable lower control arms and panhard bar in the rear, then a front end alignment is all that can be done. With that said, the rear thrust angle should be checked when doing even a front end alignment on a solid rear axle.
