Motor mounts Solids or prothane suggestions needed
Old 06-09-2014, 02:08 PM
MFJ
MFJ's Avatar
Default Motor mounts Solids or prothane suggestions needed
What are your thoughts? Solid motor mounts or the prothane?
Which solids are you guys running? I've heard the Spohn sit the engine up higher. I saw some billet mounts that look like the stock clamshells but are solid mounts. The engine looks good and the mounts need to look just as good.
I really want to run solids but have heard good things about the prothanes.
I just finished the engine build and this weekend I'm putting the motor and tranny back in.
Attached Thumbnails Motor mounts Solids or prothane suggestions needed-motor-2.jpg   Motor mounts Solids or prothane suggestions needed-motor.jpg
Old 06-09-2014, 02:37 PM
SoFla01SSLookinstok's Avatar
I am running the Spohn solid mounts. They do raise the engine a bit. One thing it did help with was my DS long tube was contacting the sub-frame. Now no contact anywhere & headers are tucked up nice. I will also put in they gave me 10+lb/ft of tq. through the entire rpm range to the wheels. I myself am happy with them, but they are def. not for everyone.
Old 06-09-2014, 02:57 PM
MFJ
MFJ's Avatar
I don't have a header clearance issue but I know plenty that did. I'm not worried about vibration, I do however want less movement in my engine mounts. I already have the prothane tranny mount and love it. It is still a daily driver but it's getting to be more race car and less of a street car each month.
Old 06-09-2014, 03:08 PM
I think the vibration factor is why people usually don't go with the solids. If she's turning more into a race car, I don't see why not to go with them, you will get the most power to the ground with your setup. Good luck man!
Old 06-09-2014, 03:36 PM
It's not mine! woo hoo!
demonspeed's Avatar
UMI has the aluminum mounts: http://umiperformance.com/catalog/in...roducts_id=556
Old 06-09-2014, 06:48 PM
MFJ
MFJ's Avatar
Those are them. Anyone ever used them?
Old 06-09-2014, 09:23 PM
Majestic9C1's Avatar
I am also looking at getting Prothane mounts... only worry I have is the vibration
Old 06-09-2014, 11:02 PM
MFJ
MFJ's Avatar
Originally Posted by demonspeed
Do these come with the mounting bolts as well?
Old 06-10-2014, 08:22 AM
Fast98Z28's Avatar
I used Prothane mounts when I swapped motors. I like them, and feels real smooth. Definitely dampens the lope of the cam. I used to have issues with my ORY hitting the bottom of my car, and that does not happen anymore. Then again I wanted mine to be a cruiser, and I hit the track here and there. I was more worried about comfort. Good luck.
Old 06-10-2014, 08:29 AM
MFJ
MFJ's Avatar
So I have to break open the factory clamshell to use the Prothanes?
Old 06-10-2014, 08:36 AM
Fast98Z28's Avatar
Yes, it takes some time. I believe the Prothane kit that I purchased came with bolts so when you drill the four places in the clamshell you can take it apart, and put it back together with the bolts.
Old 06-10-2014, 10:25 AM
demonspeed's Avatar
Any of the poly mounts you'll need to reuse your OE clamshells. It's very easy to open them up and get them ready for the new ones.
I honestly don't know how the UMI mounts are set up, but I'm sure Ramey or Ryan could answer that question!
Old 06-10-2014, 10:34 AM
UMI Performance's Avatar
Hello,
Our solid mounts, part #2323 replace the entire rubber assembly on the engine. They are direct bolt in and do not move the engine, they are built off of factory dimensions. They are also 3lbs lighter than stock rubber mounts per kit.
As for drive-ability. You will feel the solid mounts at idle while the car is sitting, while cruising you can't really tell too much of a difference.
If I can help anymore please ask.
Thank you,
Ryan
Old 06-11-2014, 06:22 AM
MFJ
MFJ's Avatar
Originally Posted by UMI Performance
Hello,
Thank you,
Ryan
Well that makes up my mind. I'm not worried about vibration. If I was, I wouldn't have headers and duals. That's part of the fun of having a V8.
I like that it doesn't change the engine height too and they're lighter. Thanks Ryan. Can't wait to get them.
Old 06-11-2014, 08:56 AM
Glad I could help!
Old 06-11-2014, 02:10 PM
chrysler kid's Avatar
Solids are the best choice. I have extremely minimal vibrations and I have a cammed car
You will need to switch back to the factory trans mount or risk breaking the tailshaft if you are 6 speed
Old 06-12-2014, 01:01 PM
MFJ
MFJ's Avatar
I've got a 4L80E. Next thing to snap on my car will be the rear end. lol
Quick Reply: Motor mounts Solids or prothane suggestions needed
