99 silverado security light on ALL THE TIME
Old 06-17-2014, 09:30 PM
firebirddude98's Avatar
Default 99 silverado security light on ALL THE TIME
Just bought the truck knowing that the security light is on all the time, but the car runs and drives all the time. It is on even when the key is out of it and the door is closed. Maybe theres a broke sensor in the door that thinks the door is open? I dont think it has keyless entry and doors are manual. Any ideas of what to look for?
Old 06-17-2014, 09:35 PM
Also some more info if it has anything to do with, the interior lights dont work when door is open and the light switch wont turn them on. I have only had this truck a few hours so i'll dog into it a little, i just wanna get that security light off
Old 06-17-2014, 09:37 PM
im-not-guilty's Avatar
Scan for codes man
Pass loc sensors were fairly common
Old 06-17-2014, 09:38 PM
hrcslam's Avatar
Which body style is it? GMT-400 or GMT-800? Is the light on while you are driving?
Old 06-17-2014, 10:18 PM
Its a 99 k1500. Body style like 99-02 so i guess gmt800? And yes. Its on when driving. And when the key is out and door is shut
Old 06-18-2014, 01:46 AM
hrcslam's Avatar
If it looks like the Suburban in my signature it's a GMT-800. If that's the case (which it should be), then the key out, door shut thing is normal. My Suburban does it too.
If it's flashing when driving that means you have a security system fault. It's telling you it's not working. Does your rig have remote start and/or an aftermarket alarm?
It should run and drive fine, but don't disconnect the battery until you know exactly what s going on with the security system. And that your key matches the Pass Key 3 system installed on your rig.
Old 06-18-2014, 04:56 PM
Figured it out!! The little computer box under the driver dash had the brown connector unconnected. Plugged it in and it went right off
Old 06-18-2014, 04:57 PM
It also fixed the door chime and the interior lights. I really like this truck!!!
Old 06-18-2014, 05:54 PM
hrcslam's Avatar
I assume your truck still starts and runs? Good find.
Old 06-18-2014, 10:15 PM
Yea it was starting and running just fine and the light hasn't came back. Now I'm gonna change the oil and pitman and idler arms. I think I'll seafoam the pistons. Guy cut the cats out and welded in straight pips cus the cats were clogged. The engine feels a little weak so it might help. Crossing my fingers that this turns out to be a good truck. I got it pretty cheap!!!
Old 06-18-2014, 10:33 PM
hrcslam's Avatar
Nice. Good luck. These engines do feel a little weak in high air temps. It gets a lot more power under 75°F.
Quick Reply: 99 silverado security light on ALL THE TIME
