Oil leaking from the "weep hole"?
Old 12-09-2014, 03:59 PM
notnilc20's Avatar
Default Oil leaking from the "weep hole"?
Hey there,
My car, a 2001 pontiac firebird formula, just started leaking oil from this weep hole between the trans and engine. It only leaks when the car is running and gets to operating temps and about one drip every 6 seconds. Are there any common problem areas that might be the cause?
Old 12-09-2014, 05:07 PM
LS6427's Avatar
Originally Posted by notnilc20
Hey there,
What weep hole....?
Old 12-09-2014, 05:42 PM
FirstYrLS1Z's Avatar
^^^ agree,what weep hole ? how about a picture ?
Old 12-09-2014, 08:39 PM
notnilc20's Avatar
Default Here ya go
Originally Posted by LS6427
What weep hole....?
Sorry here are a couple pics
Old 12-09-2014, 08:40 PM
notnilc20's Avatar
Only letting me post one pic per post on this shitty iphone.
This hole is between the trans and engine.
Old 12-09-2014, 09:03 PM
blue09rocket's Avatar
when I had a leak between my engine and transmission earlier this year, turned out to be my rear main seal, replaced it and no more leak. just a thought.
Old 12-10-2014, 06:21 AM
If it's dripping 1 drop every 6 secs,you should be able to collect enough of it after a few minutes to tell if it's tranny fluid or engine oil.
Old 12-10-2014, 06:49 AM
LilSlo1's Avatar
Most likely rear main seal on the engine or the front pump seal on the transmission. see what color the fluid is, or give it the sniff test.
Old 12-10-2014, 07:34 AM
LS6427's Avatar
I get that same problem....only one pic per post....
Thats not a weep hole...per say....its just the way they made the casting.
Looks like possibly rear main seal........if its definitely oil thats dripping out.
Have to remove the tranny to fix it. Only takes maybe 20 minutes to replace the seal itself. Only let someone do it that has done it before.....it has to be done right or it will still leak.
Old 12-10-2014, 09:44 AM
notnilc20's Avatar
Ok thanks for the info everyone. Btw, It is definantly oil that's leaking not trans fluid.
Old 12-10-2014, 12:55 PM
Daniel Richards's Avatar
just an FYI, I see a similar issue sometimes on my laptop when I try to upload multiple pictures and is has something to do with the file sizes of the combined pictures exceeding the upload limit, if I upload 1 pic then add a second pic to the same post (hitting the actual UPLOAD button between each one) it will go through, the other issue is these newer smart phones take REALLY big pictures (as far as web forums are concerned) usually in the 4MB range a piece, you could try resizing the image or reduce the megapixel setting for images you take solely to upload here to reduce file sizes and make uploads easier.
Quick Reply: Oil leaking from the "weep hole"?
