High Mileage LS1
High Mileage LS1
I have a 99 Z28 of which I'm daily driving, the car has about 182k miles and my commute is approximately 40ish miles round trip 70% street 30% highway.
Asside from general maintenance the motor itself is still running like it rolled of the factory floor. There are no knock, no pings no squeals asside from my serpentine belt issue posted in another thread. It doesnt even have the infamous piston slap. The Transmission sometimes doesn't want to shift from 2nd to 3rd but this is very very rare and it has never been rebuilt and this has lasted much longer than an average A4. When I bought it, it had a rear main seal leak but I've rectified that. It currently still does have oil leaking from the oil pan gasket, and front valley cover.
I know the inevitable is coming though, eventually it WILL have to give up the ghost... although I don't know when. I'm hoping to atleast get another 50k out of it but all bets are off.
I know early model LS1's have issues with the oil pump. Primarily I thought those were only the 98's but I found out the 99's also have the issue. I am just hypothetically running scenerios through my head.. If the oil pump does go, considering the front cover has to be removed / likewise the timing chain and oil pan must partially be removed... would it be worthwhile to install a new oil pump on a motor with this many miles? or just rebuild the engine?
depends on what the oil pump takes with it when it goes out. Oil pump replacement is much easier than a rebuild.
If you get lucky and just replace the pump...get a new timing chain too. Ive broken a stock ls1 chain and it was with less than 500hp. Cost me a whole new top end of the motor.
Besides the oil pump, LS2 chain and sprockets, I would also do an updated LS2 chain damper, and while the pan is down anyway (for your gasket replacement) do yourself a favor and replace (or at least THOROUGHLY CLEAN OUT your pickup tube and screen, and the whole pan for that matter if it is fully dropped.
I personally am also going to do an Improved Racing oil pan baffle/windage tray, and ARP, or Katech rod bolts when my pan is down, but unless you plan on autocrossing/road racing your A4 car (DOUBTFUL), you do not need this item.
Of course a new front seal and front cover gasket go on without saying.
Ditto nimrod.69 .... '99 Z28 approaching 300K miles with the stock oil pump and internal motor parts. Assuming the oil pressure gauge is somewhat accurate, it normally sits at 12 psi at idle and roughly 40 psi at speed. I do have a slight oil leak that appears to be coming from the oil pressure sensor. I've had to replace it once before .... I'm just waiting for all of this cold weather to let up before get in there to check it out. This car rocks!
mine was reading about 20psi low when it was leaking and before I replaced it.
12psi is pretty low at idle...but with 300K miles Im sure rings and bearings aren't as tight as they once were.
