Disable express on driver window?
Why? Just hit the window up switch to stop it before it hits the bottom, that's what I do. But if you still want to, jump pin E (gray) to pin D (brown) at the express down module. Make sure you verify the correct brown wire, there's two of them.
EDIT: Even easier, just jump pin E on the driver window switch connector to the brown wire on the window motor harness.
Very easy to disable......find express down module<under dash above gas pedal in my TA.........unplug module and bend Terminal C over so it doesn't connect when you plug it back into the harness......enjoy.
1st mod all my fbodies get.
How can I tell what pin is what letter?
How much do they sell for? I really could use the money or trade for other parts. Need quite a bit lol.
Thanks everyone!
^ Your method requires leaving the module plugged in. Mine and wssix's does not. Yours is also dangerous. You are suggesting bending down a 12v power contact where it could short to other pins. This is very bad advice for anyone regarding wiring, and bad practice. You might get away with it on 12v DC auto circuits without causing a problem, but higher voltage or AC circuits that would be a BIG no-no. Half-assed wiring is how fires start. Do it the right way.
