Lost Door Key
Old 02-09-2015, 01:35 AM
Darkside99's Avatar
Question Lost Door Key
When I bought my car ('99) the guy only had the ignition key. What are my options? Can I get keys made off my VIN? I would be comfortable replacing lock cylinders if I could find them! I can only find the trunk cylinder online. Help with that would be awesome. Is it true I can take a cylinder to a locksmith and they can make a key for it?
On a side note, the interior trunk release button doesn't work, any insight there?
Old 02-09-2015, 02:02 AM
slayerized6's Avatar
A locksmith could probably make a set of keys. It would cost a lot more money money to replace key cylinders; especially if you have a t-top car too.
Old 02-09-2015, 02:15 AM
Tuskyz28's Avatar
Should be able to take the Vin number and proof of ownership to your local GM dealer and have a key made. It shouldn't cost that much cause the door key doesn't have a chip installed in it like a ignition key.
Old 02-09-2015, 10:50 AM
Daniel Richards's Avatar
Assuming you find a dealership that still has the blanks and the computer system had the info put in properly from the start. I had this done and went out to the car only to find it didn't work ANY of the locks. I ended up buying a set of lock cylinders off ebay from the seller "wolfsecurityhardware" that was a "kit" of both door lock cylinders and the trunk lock cylinder, just looked and it's currently selling for 55 bucks (I paid 50) and just swapped them all out, so I have door keys but can't "lock" the t-tops or glove box, which is still a step up from where I was with no door key.
FYI the doors are so easy to do you will spend more time taking the door panel off then actually swapping the cylinder.
Old 02-09-2015, 11:41 AM
LopeyZ's Avatar
My house was broke into a couple years ago and keys stolen! Lucky for me I stored the car elsewhere. Took my title to the local dealership and they cut me new keys. Worked great. Only issue I had was the original ignition cylinder was swapped so I had to buy a new ignition cylinder and blank key. Dealership told me which key to buy so I get the right resistor.
Old 02-09-2015, 02:45 PM
Spartan7's Avatar
That's also assuming your locks had never been changed.
Old 02-09-2015, 02:52 PM
hardbones's Avatar
Location: Illinois, as close to "Normal" as I can get...
Take your title, drivers license and go to the GM dealer
They can cut it by code for pretty cheap since its not a chip key
You just have to prove you own the vehicle
Old 02-09-2015, 02:59 PM
Tuskyz28's Avatar
Exactly!!
Old 02-12-2015, 06:31 PM
Darkside99's Avatar
Thanks for the all the great info. I will start by going to the dealer.
Does anyone actually lock their T-tops?
Old 02-13-2015, 08:18 AM
hardbones's Avatar
Mine are locked on the car at all times
Have heard to many horror stories about T-Tops flying out at speed
Old 02-13-2015, 01:26 PM
Nathan C's Avatar
I had a t-top in my old Camaro fly off on the freeway once, so yes, I always keep them locked now.
Old 02-13-2015, 01:42 PM
I honestly don't understand how a t-top "flying off" could be prevented by locking it, the lock only keeps the latch from being opened, if you t-top could come off while latched it could come off while locked, unless your latch just flaps around around on you.
Old 02-13-2015, 04:26 PM
hardbones's Avatar
As the mechanisms get older, they get sloppy. Locking them keeps the latch mechanisms closed and secure
Hit a few bumps with a worn out, unlocked latch and it can come loose...
Quick Reply: Lost Door Key
