trans am headlight problem
I have read several threads but could not find anything solid. I have a 2002 Trans Am and the drivers side headlight will not raise or lower. I was thinking it was the motor, so I replaced the motor, it still does not work. I was then thinking the connector since it looked a little corroded, i cleaned it best I could. But both the regular light and bright light still come on, so if it was the connector wouldn't the lights also not come on. Could it be the headlight control module, or if it was that would both lights not work? Anyone have any ideas on what it could be? Also the motor does not make any kind of noises or anything.
Thanks for any help,
Brandon
Brandon
thanks, I tried that today. I switched the drivers and passenger side fuse just to be sure, still did not work. I also switched the headlight control module with one on another car to see if that was the problem, it still did not work. Now I am thinking that it must be the connector, unless anyone else has any other ideas.
Save the manuals!
I'd try putting 12 V to the headlight motor wires to make sure it works. If so, try cleaning the connector contacts more. Just a little bit of corrosion in the wrong place will cause a problem.
This sounds like a connector problem. The connector should have 6 wires if I remember correctly. Two for the high beam lamp, two for the low beam lamp, and a red and black for the headlight motor. This sounds like you aren't getting contact across the two lights for the headlight motor.
