Side marker problems on a '99 T/A
Old 03-23-2015, 04:44 PM
LTX_Alex's Avatar
Default Side marker problems on a '99 T/A
Just need some help with a problem I've been having lately. One of my side markers are brighter then the other. My drivers bulb is more dim then the other. So, I thought the bulbs needed to be replaced. (Changed both of them) Once I changed it, it didn't solve the problem. The next day I went to the junkyard thinking it would be the actual little sensor on which the bulb connects to was faulting. I changed it, fused the wires put the bulb on & it didn't solve the problem. Like, the actual drivers side bulb is lighting just a little bit but its no were near as bright as the passenger side? I don't know what else it can be. Any help or solutions are welcomed. (99 T/A A4.)
Old 03-23-2015, 07:32 PM
Save the manuals!
wssix99's Avatar
I'd check the voltage at the socket. I suspect your dim socket will be low. From there I'd check the ground and socket condition first.
Quick Reply: Side marker problems on a '99 T/A
