Coolant getting into Power Steering Fluid?
My power steering fluid keeps getting milky looking really fast. Is it possible that coolant from the power steering cooler is getting into it?
Would it be ok to just bypass the cooler (make a U with the hose) to see if it stops?
My coolant looks completely clean....I've noticed that when i turn the wheel a lot when not moving it drags my idle down some. Maybe the pump is going out?
The cooler is starting to fail, Coolant pressure is higher than the return in the steering system. So you are just getting a little coolant pushed into the oil, Once it fails completely the oil in the cooler will be in the coolant too. I'd disconnect it now before that happens. Its the 1st thing I do to these cars, you don't need it unless you race.
You can actually install an 'real' cooler without much effort. Made a write up if you'd be interested in that:
https://ls1tech.com/forums/general-m...er-delete.html
Save the manuals!
I think we have pretty good consensus in the community that the stock cooler should either be replaced with an aftermarket option or deleted entirely (good part or bad part) - so there's no harm there. https://ls1tech.com/forums/general-m...g-success.html
You may address the cooler first, see if you still have milky fluid and then go for the pump from there.
<comment deleted> Coolant pressure rises quickly after the engine is started. I can't even begin to post back, <comment deleted>
<comment deleted>
<comment deleted>
Save the manuals!
Some people start the weekend early...
I'm happy to extend this thread in to some technical discussion, when you are ready. If you want to talk about the PS cooler/heater consipracy, I guess we can do that but people have taken real measurements with real temperatures (posting in the Power Steering Cooler thread) and I think we put that to bed a long time ago.
If you are saying that the coolant pressures are greater than the P/S rack pressures at all times and that P/S fluid can never flow backwards in to the coolant system, show us some information or data.
Coolant pressures do rise quickly, but they rise they don't rise instantaneously like the power steering system does. Guidance to GM Techs lists oil in the coolant as a symptom and many of us have seen it happen when our coolers failed. So, if you have evidence to the contrary, it would be good to see that also.
Thanks guys!
I believe I'm just going to replace the cooler with a normal radiator hose and bypass it.
I don't think I have any needs for a PS cooler.
Can I just cap off the PS oil lines or do I need to run a hose from the inlet to the outlet?
And....when the factory PS fluid cooler springs a tiny tiny leak, which they almost ALL do at some point, when you shut the engine off and it cools down over time it will suck PS fluid out of the cooler......into the cooling system. Just like coolant is supposed to get sucked back into the cooling system from the overflow tank......when things cool down. So PS fluid doesn't necessarily have to get pushed into the cooling system while you are driving around......
98ws6blk
Put a cooler on it....cooler temps (((as opposed to VERY HOT temps))) perform better and they will make your pump and its rubber hoses and plastic reservoir tank last longer. Heat kills everything thats not metal........over time.
98ws6blk
LS1Tech Administrator
Received 1,487 Likes
Also, if you are the type who changes your PS fluid with some amount of regularity, then you have even less need for a cooler. Higher temps have a long term affect on fluid life, but if the fluid is kept fresh then this becomes less of a concern.
Considering you live in the south, cooling might be more of a concern for you. It just doesn't get hot enough for long enough up here to worry much about this unless you use the car in such a way as to put a lot of stress on the steering system (such as road racing, etc.)
